NO HEAT!!! PLEASE HELP!!!!!
Old Oct 6, 2008 | 10:25 PM
Dennis's Avatar
ud
Default RE: NO HEAT!!! PLEASE HELP!!!!!
As long as you can see coolant in the reservoir..that ain't the problem..It is more than likely a damper control door stuck closed inside the car behind the dashboard on the HVAC system..and yes, it is a pain to get at.
Old Oct 7, 2008 | 03:06 PM
I would make sure that you do not have a cracked expansion tank as it's a common fault, fill it back to the full level and check for loss of fluid, you may see it dripping behind the wheel.
Another possibility for the loss of heat may be the heater control valve, if you do a search you should find a lot of information. Good luck.
aode06
Jul 28, 2023 02:26 PM
Delta66
Oct 4, 2015 05:40 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
