Overheating Issue Jaguar s-type 3,0l 2000 mod
Hi all
I need help?
Has a Jaguar S-type 3,0l 2000 Model here that does not lose Aquarian after driving 10 to 15 minutes to get warm
I have replaced the solenoid valve for the heat it has 5 intake tube
Exchanged water pump, press each cylinder of compressed air no leakage, pumped up pressure on the expansion tank 1bar
for one hour without loss of pressure.
Seems like there is no circulation of the expansion tank
Bleed at the thought which comes at times spitting steam
No water in oil not exhaust either.
The car will be warm and good inside, but a / c does not work (but has not checked whether it is ac bag pressure)
But the car was going to be cold inside when I put down the temperature inside the car ??
But the bubbles when I stop the car. the bubbles of air in the expansion tank.
I use onley Clean water and no termostate at the moment .
Does anyone have something sensible and Getting by I'm more than grateful for all the help I can get
Now I stand really firm here
HELP
I need help?
HELP
You must reinstall the correct thermostat facing the correct way and then refill with the proper coolant mixture for your location and then bleed the system.
Use the search function as there are many threads on how and when to bleed the X200 cooling system.
mikiep
Dec 20, 2019 07:37 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
Jan 14, 2016 11:32 AM
