P0171 and P0174
Old Mar 2, 2012 | 09:11 AM
99snake's Avatar
Question P0171 and P0174
At first I just had a P0171. I cleaned the MAF sensor and it cleared up for a few weeks. Now I'm getting both. Where should I be looking for a vacuum leak on a STR? I think I might just try a new MAF. Thanks guys.
Old Mar 2, 2012 | 09:46 AM
joycesjag's Avatar
Usually those 2 codes point to a vacuum leak.
Old Mar 2, 2012 | 09:58 AM
99snake's Avatar
Where should I look for a leak? Where are the common places?
Old Mar 2, 2012 | 10:02 AM
Brutal's Avatar
The intercooler ducts, and down below the throttle body before the sc. The brake booster pipe entrance into the intake elbow. Im doing 1 right now on a 2009 xfr
Old Mar 2, 2012 | 10:53 AM
bfsgross's Avatar
Ditto to Brutal. Have the same code: presently in the shop for a new brake booster port.
Old Mar 2, 2012 | 12:46 PM
aholbro1's Avatar
Everything in the airpath between the MAF and where it (intake airflow) splits off to separate banks would be suspect, since you are getting codes for both banks. Having said that.....I had both on a 3.0L and could find no evidence of vacuum leaks. Swapped maf's with the other 3.0L in the stable and cured the problem for about a year...when it returned...it came up on the other car...the one that didn't have it before. Swapped back (because that one is based out-of-state with daughter at college) and ordered a new maf. Didn't get any codes in the week and half or so I had the "bad" MAF back on the 05. Good luck with it.
clubairth1
30
Sep 3, 2025 04:38 PM
Bob Gelston
Sep 14, 2015 11:08 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
NinoGrimace
Aug 26, 2015 05:15 AM
