P1549 OBD Trouble Code
Old Nov 1, 2012 | 07:15 AM
chromedragon's Avatar
Default P1549 OBD Trouble Code
Hi,
A while back, I received this error and found it to be one of the connectors on one of the IMTs. The wire has pulled from connector and therefore this IMT doesn't work.
Since the wire has pulled out of connector, I would like to know if there is some sort of pre-built kit, a connector with attached wires that I can splice onto wires in car.
Thanks for advice in advance.
Old Nov 1, 2012 | 08:30 AM
jchavez76's Avatar
I don't know if this will help. Many of the connectors on these Jags are also used on Fords. is a link to a Ford pigtail catalog.
http://www.fordtechservice.dealercon...torcatalog.pdf
Maybe you can find one here that matches yours. Of course, there may be others here that know an easier way to find it. I just wanted to reply before I get to work.
Good luck.
Old Nov 2, 2012 | 12:35 PM
Thanks for the link jchavez76
Jpav27
Jul 31, 2022 06:43 AM
philwarner
25
Jun 26, 2021 05:43 AM
Poet
Oct 6, 2015 09:40 PM
Bob Gelston
Sep 14, 2015 11:08 PM
jagfool
Sep 14, 2015 07:50 PM
