Qwiketz intake elbow thread including pics and dyno charts
Old Mar 31, 2012 | 01:17 PM
V8 Str's Avatar
Thumbs up
Originally Posted by qwiketz
Hi guys. Many of you guys know that I have been in the process of coming up with another intake elbow. I've come far enough at this point to at least warrant an update. It's not done but I'm close.
A little background about my elbow. It's out of stainless steel with a 1/2" bung welded on. My intention is to connect the 1/2" hose to the stock 90* elbow off the cam cover. I will also be trying to find a replacement fitting that will work. I tried two today but they're not quite right.
I will be using reinforced silicone couplers and t bolt clamps.
I'm going to test fit it tomorrow after work and I'm hoping to get it on the dyno either Saturday or early next week. I will be doing runs with:
-stock, no alky
-intake tube, no alky
-intake tube, 375 jet
-intake tube 625 jet
Below are some pics of my prototype. I probably will be doing a run of these shortly once I get the dyno results and test fit with the stock air box (mine doesn't have it). If all turns out good then I'll talk to my fab shop that did the work on this one and track down the other components.
Here's some pics of the tube itself....
Looking good, i am in for this as i was going to fab one over here to go with my Mina Intake filter/heatshield i now have...!.. keep us posted
Old Mar 31, 2012 | 01:22 PM
Mikey's Avatar
Originally Posted by Michael Star
I know you try to help out as much as you can, but you are the most negative person on this board. Just gets annoying to see your posts after a while.
And your contribution helps in what way?
Old Mar 31, 2012 | 04:06 PM
bfsgross's Avatar
Though my 03 STR wears the Mafioso air intake tube, I feel it appropriate to thank qwiketz for his experience, resources, and time in the development of this STR modification. We're very fortunate to have each other and talent to boot.
Old Mar 31, 2012 | 04:40 PM
Let's try and stay on topic, air intakes and throwing stones don't mix well!
Old Mar 31, 2012 | 06:55 PM
qwiketz's Avatar
Thanks for the props. I'm in between home remodel projects so I can get back to my real hobby, designing and fabbing up parts. This thing is so simple but I just haven't had the time to put into it until now. I need to knock this out, redo my suspension bushings and then get on the vette. I'm itching to break into the 9's and I have the power to do it. Just need to get some stuff sorted out.
Anyhow, thanks to all for the interest in the thread and it looks like the next big update will be Friday. Until then I'll just be keeping an eye out for people's thoughts on the finish.
Old Mar 31, 2012 | 08:50 PM
QuartzSTypeR's Avatar
You might want to consider having the intake ceramic coated like the mafioso style ones. If you leave the metal plain or just painted, its more likely to heat up quicker and retain that heat, even more so than plastic. If the shop that is supposedly building mine (wtf already over 3 weeks?) ever finishes it, it is supposed to be a 3.5" tubing with a ceramic coating.
Old Apr 1, 2012 | 05:16 AM
V8 Str's Avatar
Sent pics link via PM for you of the heat shield in situ , if you want me to strip it out at any point for more detailed pics/shapes/fitments just shout..!
Old Apr 1, 2012 | 05:29 AM
  #28
Staatsof's Avatar
Default Let's un-bunch our panties and get back to work?
I suppose you better add me and few others on here to that list too.
I always thought that critical thinking leads to better results?
I haven't read all of his posts so maybe he is a bit of a curmudgeon but I also asked what this change is supposed to accomplish.
Now I did follow Mafioso's project which was supposed to thermal isolate the intake tract somewhat.
How does that happen with this piece?
Old Apr 1, 2012 | 09:10 AM
Mikey's Avatar
Never mind -just my addled brain again plus a bit of paranoia.
Old Apr 1, 2012 | 09:16 AM
  #30
bfsgross's Avatar
LOL! We're all a "Little Piece of This and Piece of That" This's what makes it all interesting and fun.
Old Apr 1, 2012 | 09:20 AM
  #31
Mikey, I thought Staatsof was backing you up!
Now didn't we say something about staying on topic?
Old Apr 1, 2012 | 10:40 AM
  #32
Robinb's Avatar
What would be the problem with using good old heat-wrap to insulate the pipe? Might even cut down on the noise.
Old Apr 1, 2012 | 11:06 AM
  #33
Mikey's Avatar
If the difference between ambient air temp and under hood temp is small as inferred by the OP, then insulation wouldn't be of benefit. Hard measurements of the actual temps would reveal all though.
Not to hijack, but my generation of Corvette came with a cowl induction set up from the factory and great promises of improved performance from cold air collected at the base of the windshield being ducted straight into the carb. Unbeknownst to me, an electrical fault prevented a flapper valve that opened/shut the ductwork on mine from functioning for an extended period. After repairs, I noted little change other than more carb noise with the duct work open at full throttle. I then instrumented the air filter housing to monitor and record temps under all sorts of conditions including a number of 100+ mph passes to take maximum advantage of any aerodynamic effect.
Very long story short, the cowl induction system reduced the carb inlet temp by a whopping 1 degree F as compared to when the engine was breathing underhood air from the standard 'twin snorkel' inlets.
There was actually a greater variation in temperature depending on whether the car was pointed into or away from the prevailing winds which were just short of 20MPH that particular day.
Now,
Old Apr 1, 2012 | 02:45 PM
  #34
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
IMHO, heatwrap would be unattractive and detract from the aesthetics of the system. Cermaic coating both sides would be superior and possibly powder coating the outside (if practicle with selected colors) would give zing to the intake..such as Mafioso did..
Old Apr 1, 2012 | 03:10 PM
  #35
Staatsof's Avatar
Yeah I thought I was helping but it's OK.
A couple things here:
If there's not really any under hood heat hitting that pipe while it's under way then probably the ambient airflow is going to reduce the temp of the pipe. In which case I would think that aluminum would be the best material.
But I have no idea about what the actual conditions are. A good reason to instrument the actual situation.
I just wondered if a plain SS pipe is going to get head soaked in hot summer weather when you're at a light? I thought that's what Mafioso's version was all about?
I'm just asking guys.
Old Apr 1, 2012 | 03:36 PM
  #36
Mikey's Avatar
Thanks for posting. It's me that's confused- again.
Old Apr 1, 2012 | 06:05 PM
  #37
Robinb's Avatar
You are right, of course. But yet, would not heat wrap be a much better insulator than ceramic? And if that improved insulation added an extra 10HP(?), who would care about under-hood aesthetics?
Old Apr 1, 2012 | 07:09 PM
  #38
Mikey's Avatar
A 10 HP increase would certainly be a worthwhile and remarkable advance. The rule of thumb is that a 10*F decrease (or avoidance of increase) in inlet temp is worth 1% in HP. The type-R is rated at a peak 400HP, meaning that a 10 HP = 2.5% increase. This translates into a required decrease of 25*F inlet temp compared to the stock config.
I doubt that even under stationary conditions the underhood temps in the area of the inlet are 25*F higher than the cold air inlet in front of the grill. With the car in motion, the differential is bound to be less as the OP has stated and as per my fooling around on the other car.
Equally important if not more so is the volume and velocity of the air going though the elbow- the engine pumps roughly 11,000 litres of air per minute at red line. Given the short length and diameter of tubing used, (ie. total surface area acting as a radiator) and the probable small differential in inlet vs. under hood temp, any heat gain might be difficult to even measure.
Old Apr 1, 2012 | 07:17 PM
  #39
bfsgross's Avatar
If wrapping the pipe yields little transference of heat, IMO, I couldn't give a hang how the pipe looked. Wrap would give it that "Tech" look, like we're Einstiens.
Old Apr 2, 2012 | 12:59 AM
  #40
qwiketz's Avatar
I picked up a thermometer with a probe so I'll create another thread describing what I see as far as underhood temps when in traffic, cruising and at idle. I'll create that tomorrow night.
Based on what I see there, I'll figure out which direction to go. Personally, I think ceramic coating of the intake tube is a waste of time and is just over thinking things since there are so many other pieces that soak up the heat. For instance the part after the tube is metal and gets burning hot and then it goes to the intercoolers that are cooling down the charge using radiator fluid.... I think it's an uphill battle you're not going to win unless you run a killer chiller and a closed loop intercooling system. But, once again, thats just my opinion.
