Rear Differential
Old Jun 7, 2017 | 07:16 PM
abgusaf's Avatar
Default Rear Differential
Hello,
My rear differential just exploded in my STR. I was just wondering the compatibility for a replacement diff. I have found diffs on eBay that say they fit 4.2L S-type, I was just wondering if the V8 diffs are all the same, or there is a specific one for the STR.
And by exploded, there is a hole in the differential.
Thanks in advance
Old Jun 7, 2017 | 11:27 PM
Datsports's Avatar
as far as I'm aware the 04/05 xjr is the same nugget . you will need to match your gear ratio , to keep the ecm and speedo happy . although i believe this can be modified via SDD/IDS if necessary.
