removal/exhaust manifold/heads help!
good morning guys this is thread related to other one . cylinder heads bad gasket removal process .. I'm down to needing to remove exhaust manifolds so we can pull both heads out ( doing the gaskets on both of them )
I don't have access to JTIS files just FSM which I have followed to get it to this point
any suggestions on doing that ! greatly appreciated
keep hearing to remove engine HOPE that's not what I have to do on 2005 stype 3.0 !!!!!
Got it ! removed two nuts to manifold both sides , removed fuel injectors off top ,,
heads came out with manifold .. I will disconnect those before I take it in for inspection to a place here id Dallas and also replace gaskets and bolts on manifolds
