replacing std grill with wire mesh - 04 S
Old Feb 26, 2008 | 08:52 AM
mandoman's Avatar
Default replacing std grill with wire mesh - 04 S
I purchased a mesh grill on Ebay, but came with no instructions. Any suggestions on how to install?
Also can anyone tell me how to remove the existing grill and shroud?
I have removed the top two #10mm screws but it is still attached.
Thanks!
Old Feb 26, 2008 | 10:36 AM
03 S Type's Avatar
Default RE: replacing std grill with wire mesh - 04 S
I just did the same swap. There's actually 4 bolts you have to loosen up. If you still have the stock grille I think there's a way to kinda poke through the front part to access the other two bolts. It's hard to explain. If noone else posts a detailed guide by hte time I finish up with my work today, I'll post photos for you to go by.
GL with the swap!
Old Feb 26, 2008 | 10:59 AM
mandoman's Avatar
At the upper area on each side, there are 2 #10mm hexheads that I have removed.
Looking down from above and behind the grill, there are 2 torx screws, one on each side about half way down.
Are these the 4 connections you are referring to?
Thanks for the reply!
Old Feb 27, 2008 | 06:51 PM
mandoman's Avatar
Nevermind...I figured everything out. Installed the mesh grill this a.m.
Looks factory. Just took my time and didn't even break off any of the plastic tabs removing the chromed plastic trim ring!! Bought a can of matching dark grey metallic paint to touch-up the places where I cut the bars out.
Thanks anyway guys.
JarodL
Mar 7, 2024 01:39 AM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
