Roughness after cold start 2005 3.0 S-type
Old Yesterday | 02:06 PM
Doug's Avatar
Default Roughness after cold start 2005 3.0 S-type
A small issue has recently developed.
On a cold start (fully cold, after sitting overnight) I'm getting a bit of engine roughness. I call it a "chuggle" or "tuggle", if you get what I mean. This lasts for maybe 10 seconds at the most and will not repeat until the next morning.
No codes. No CEL. About 45k miles on the car, BTW
At this stage it is really just slightly annoying curiosity. It's probably a case where I'll have to wait for it to get much worse before there's anything to wrap my hands around, so to speak. Unless, that is, some of you with lots of S-Type experience can recommend some quick-n-easy checks that might be fruitful
Thanks for any thoughts and advice.
Old Yesterday | 07:51 PM
Peter_of_Australia's Avatar
Well, I recently discovered ChatGPT for myself... Whatever I want to know, I just ask.
I asked it for you: "Why is there roughness for 10 seconds after cold start on Jaguar S-type 2005 3.0L?"
...and the reply makes total sense to me:On a 2005 Jaguar S-Type 3.0, rough running for only the first ~10 seconds after a cold start is usually caused by the engine struggling during its “cold enrichment” phase. Once the ECU switches toward normal operation and the engine warms slightly, the symptom disappears.
The most common causes on the Jaguar 3.0 V6 are:
  1. Vacuum leaks
    Very common on aging Jaguars. Rubber hoses, intake seals, or breather elbows crack with age. When cold, the leak is worse because rubber contracts. After a few seconds, the mixture stabilizes and the idle smooths out.
  2. Weak ignition components
    Worn spark plugs or failing ignition coils often misfire only when cold. Cold starts require a stronger spark because the fuel mixture is richer.
  3. Dirty throttle body or idle air system
    Carbon buildup can make idle control unstable during startup. This is especially noticeable for the first few seconds after ignition.
  4. MAF sensor contamination
    A dirty mass airflow sensor can miscalculate cold air density, causing a lean mixture and rough idle until the ECU compensates.
  5. Coolant temperature sensor drifting
    If the ECU gets the wrong temperature reading, it may inject too much or too little fuel during cold start.
  6. Fuel injector leakage or poor spray pattern
    One injector may dribble fuel overnight or atomize poorly when cold, causing a brief stumble or misfire.
For the Jaguar S-Type specifically, I would first suspect:
  • intake/vacuum leaks,
  • ignition coils,
  • or spark plugs.
Especially if:
  • the car has over ~150,000 km,
  • the roughness feels like a brief misfire,
  • or there is occasional hesitation under acceleration.
Things you can check yourself:
  • Listen for hissing sounds after startup.
  • See whether RPM fluctuates.
  • Check if the Check Engine Light ever flashes briefly.
  • Scan for pending codes even if no warning light is on (codes like P0300–P0306 are common for cold-start misfires).
  • Inspect old vacuum hoses around the intake manifold.
If you tell me:
  • whether the idle shakes or only sounds rough,
  • whether there are misfire codes,
  • mileage,
  • and whether it happens only overnight or every cold start,
I can narrow it down much further.
__________________
I then wrote: "It happens only overnight" - and the reply was:If it only happens after the car has sat overnight, that narrows it down quite a bit on the 3.0L Jaguar V6.
The most likely causes become:
  1. Small vacuum leak (very common)
    Overnight, seals and rubber hoses cool down and shrink. On the first start, extra air leaks in and the mixture becomes too lean for a few seconds. As the engine warms slightly, the rubber expands and the ECU corrects the mixture.
    On the Jaguar S-Type, common leak points are:
    • PCV/breather hoses
    • intake manifold seals
    • vacuum elbows behind the throttle body
    • cracked rubber intake duct
  2. One ignition coil getting weak
    A marginal coil often misfires only when:
    • cold,
    • damp,
    • and during rich cold-start fueling.
    Once the engine runs for a few seconds, the misfire disappears completely.
  3. Fuel pressure bleeding down overnight
    If the fuel system loses residual pressure while parked:
    • the first start is briefly lean,
    • the engine stumbles for several seconds,
    • then runs normally once pressure builds.
    Causes can include:
    • weak fuel pump check valve,
    • leaking injector,
    • fuel pressure regulator issue.
A useful clue:
  • If the engine cranks longer than normal before starting → suspect fuel pressure bleed-down.
  • If it starts immediately but shakes/rough-idles → vacuum leak or ignition is more likely.
Another important clue:
  • If roughness is worse on cold mornings or humid days → ignition coil is highly suspect.
  • If turning the engine off and restarting immediately makes it smooth → again points toward overnight-related conditions like leaks or fuel pressure loss.
A few easy tests:
  • Open the bonnet after a cold start and listen for faint hissing.
  • Spray a little throttle-body/intake cleaner around intake hose joints while idling (carefully). If idle changes, there is likely a leak.
  • Scan for pending misfire codes even without a warning light.
  • Check spark plug age. Old plugs accelerate coil failure on these Jaguars.
On this engine, I would personally start with:
  1. Inspecting vacuum/breather hoses,
  2. Reading pending OBD codes,
  3. Then checking coils/plugs.
Those are by far the most common causes of this exact symptom on aging Jaguar AJ-V6 engines.
Old Yesterday | 09:55 PM
Doug's Avatar
Checking for vacuum leaks is easy enough. And non-invasive.
Cheers and thanks!
AlainDW
Dec 26, 2024 11:27 PM
Henry Bartle
Nov 5, 2024 09:34 AM
Vandyone
Feb 22, 2020 12:29 PM
ratgawd
Dec 27, 2014 12:21 PM
JoniFIN
Sights N Sounds
Apr 2, 2010 10:22 AM
