S-type oil changes
Old Oct 19, 2011 | 09:33 PM
  #41
lk2cmp2's Avatar
Default Change my Oil Fast
I don't deal with the pan on my 03 s-type. I just leave it in the garage.
Now if there's a leak I can see it right away and changing oil is easy.
Old Oct 20, 2011 | 10:02 AM
  #42
JakRox's Avatar
I loved this post being a new S-Type owner. The one point that struck me most was the 10K shelf life between oil changes. I've always done 3.5K changes. Also, the cars I have had recently advised me of oil changes, I was wondering if the S-type does also. I can't seem to find a clear cut answer in the manual.
Tim
Old Oct 20, 2011 | 10:40 AM
  #43
Jon89's Avatar
The owners manual indeed specifies 10,000 miles between oil changes. Most of us believe that would be treating the engine too harshly, especially if you choose to stay with conventional oil as I have. I settled on a 6,000-mile service interval when I purchased the car, and have stuck with it ever since. That works just fine for me....
And no, nothing on your dashboard will illuminate to notify you it's time to change the oil. You must make that decision yourself....
Old Oct 20, 2011 | 10:55 AM
  #44
Mikey's Avatar
I'm not sure that the statement that "most of us believe that would be treating the engine too harshly" for the 10K oil change interval is true, irrespective of oil type. Even if the majority holds that opinion, it's not based on any hard evidence that changing it at the OEM interval or greater causes any harm. This 10K interval is not uncommon on modern cars, even on our lowly Honda Civic.
The 3K-ish oil change interval was appropriate back in the 60s or 70s, not today.
Old Oct 20, 2011 | 01:18 PM
  #45
vance580's Avatar
Also with the S type having an oil cooler that helps make the oil last longer per say. On my STR my oil will stay new brown till about 5000 miles then it will finally start to darken. I change about 6000 miles just because I'm ****.
Old May 17, 2012 | 10:16 AM
  #46
usajay38's Avatar
I just bought a 2000 s type 4.0, i went to walmart and they told me they could not change my oil because they did not have a torch wrench. what is a torch wrench needed for?
Old May 17, 2012 | 10:59 AM
  #47
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
They probably meant "torque" wrench and if they didn't have one, tell them to go to PEP Boyz and buy a good one or Auto Zone or......
Old May 17, 2012 | 11:11 AM
  #48
Jon89's Avatar
The moral of this story is "never go to Walmart for an oil change"....
Frankly, I wouldn't even allow Walmart to change my wiper blade inserts....
Old May 17, 2012 | 11:18 AM
  #49
jag79's Avatar
Planning on getting an oil filter wrench. Anyone know the exact diameter of the STR oil filter so I can get the right size Oil Filter Wrench? Maybe this correct size 3 1/8" to 3 7/8"?
http://www.amazon.com/Lisle-63250-Ra...pr_product_top
Thanks.
Old May 17, 2012 | 11:32 AM
  #50
Mikey's Avatar
Originally Posted by Jayt2
They probably meant "torque" wrench.
+1, and maybe it's just as well.
Old May 18, 2012 | 02:01 AM
  #51
plums's Avatar
Amazon.com: Lisle 63250 Wide Range Filter Wrench: Automotive
Thanks.
V8?
Pretty sure that it would be too big because the oil filter is just about 3 inches.
A smaller strap wrench works well, or the Channellock model 209 is the right range.
Old May 18, 2012 | 06:18 AM
  #52
usajay38's Avatar
I changed the oil myself with no proiblem.
Thanks,
john
Old May 18, 2012 | 06:46 AM
  #53
Mikey's Avatar
Thanks,
john
Well done! Sort of makes you glad that Walmart couldn't/wouldn't do it, huh?
Old May 18, 2012 | 08:06 AM
  #54
Amadauss's Avatar
Thanks,
john
Get yourself a couple of those drive up ramps, helps a great deal. Might be surprised how much you use them. Also a couple of good jack stands and a good jack. Really never use the one made for the car and if I do, only if a flat while driving. Good luck with the car.
Old May 18, 2012 | 08:46 AM
  #55
The Chris X's Avatar
A strap wrench comes in handy for a tight filter - even a cheapo strap wrench from Harbor Freight will do. I run K&N oil filters that have a 1" nut tack welded to the top of the filter, so then it's just a socket job. Filter is about $13 or $14.
The drive up ramps do come in handy, but be aware that if your car sits low or has a low lip, like my STR, you have to get either ramps that have a long rise, or use some wood to make a "step" to get on the ramps and not hit the bodywork.
Old May 18, 2012 | 11:00 AM
  #56
jag79's Avatar
Originally Posted by plums
V8?
The S type R is V8 Supercharged, so yeah if your saying the oil filter is small then I guess I'll need this smaller diameter oil wrench; 2-1/2 inch to 3-1/8 inch in diameter.
Amazon.com: Lisle 63600 Oil Filter Tool: Automotive
I'm not a big fan of those strap grips, so I was looking for an alternate option.
thanks
Agree Chris, my STR is the same its really low to the ground since I have the Arden Springs on it, and I advise anyone if you don't have your Jag lowered to get these Race Ramps, they are the best; perfect size and I use them for my other cars which makes life a lot simpler.
Amazon.com: Race Ramps RR-56 56" Race Ramp: Automotive
Old May 19, 2012 | 06:32 AM
  #57
usajay38's Avatar
used my ramps, was able to remove filter with hands, easy job
Old May 20, 2012 | 08:22 AM
  #58
chromedragon's Avatar
You mean for the past 100,000 miles (after warranty), I was supposed to be using a torque wrench when changing my oil?
I change my oil every 5000 miles. This is a good round number for me. I use conventional oil, Castrol then changed to Valvoline. No real reason. It was time to do an oil flush and I decided to start with another brand. A while back I purchased an oil locking wrench from Autozone. It serves its purpose. I only use it to loosen the filter and to get a grip when removing. I don't use a torque for the drain plug or filter. But that is just me.
I know I have to put the belly pan back on my jaguar. I am sure this is the reason road noise has increased.
My vehicle is approaching 150,000 miles. For eight years, I have driven the car almost 100 miles daily. I hope it exceeds the mileage my SAAB had when I finally put it out to pasture: 253000 miles. I would be might happy.
Old May 20, 2012 | 03:18 PM
  #59
plums's Avatar
The cheap rubber strap grips are also good for pickle jars and the coolant reservoir cap
The Channellock 209 will fit well as it was tested in the store. Home Depot stocks it because it is also used for PVC plumbing pipe.
The one that you have shown has a problem in that it fits over the end. You may not have clearance to do that. And, it is right at the limit in terms of diameter.
Old May 20, 2012 | 03:42 PM
  #60
Amadauss's Avatar
Originally Posted by ohsigmachi
Sorry to break it to you, but you probably are whining just a bit too much here. Compared to a few other cars I've owned changing the S-type's oil is a snap.
I do have a couple of quick pointers for you though.
1. Buy new hard ware for your under tray. I took my existing hardware to Lowe's and got all SS washers and wingnuts that really make removing the undertray much faster.
2. Get some ramps for the front of the car. Wal-mart sells Rhino brand ramps at good prices that will make servicing the car much easier (don't forget the tire stops for the back wheels!)
3. 10K miles on the oil is absolutely within the realm of possibility. If you drive your car 75% (or more)of its mileage on the freeway at cruising speeds, this car is pretty easy on the oil. You also have to take into account this car holds 2.5 quarts more oil than nearly every other car on the road(five quarts is your average fill, with many econo cars only taking 4qts!!). Especially with full synthetic and a quality filter (the Jaguar branded filter is a good one; I've cut it open), 10,000 miles is a no brainer.
I have a different view on when to change but that said, just wanted to suggest don't get the cheap tire stops because they are not really that good. I use 4x4 pieces of treated lumber. Works great. And without the Rhino ramps the time is double or triple to do the job.
