s-type passenger door lock prob.
Old Apr 8, 2010 | 02:30 PM
nanita10's Avatar
Default s-type passenger door lock prob.
Im having problems with my passenger door lock it seems to be stuck when its in either lock or unlock position, to lock the door i have to press on it and i can hear something mechanical not sure if its a motor of sorts. When i unlock the door from driver side all door unlock except passenger door but all of the other locks go back to lock position within a sec. If my passenger door is unlock position and i try to lock the car from driver side all doors lock except passenger lock but all locks go back unlock position within a second.
Does anybody have an idea of what could be the problem?
Thanks.
Old Apr 8, 2010 | 04:41 PM
Mafioso's Avatar
Sounds like a rod is sticking you need to remove the door panel and inspect the rods for binding and use some sort of a film lubricant on the clips that hold the rods. I can't recall I'd the pass door has a keyhole if so put in the key and turn it without forcing it and that will tell if the lock rod or the tumbler rod is binding up.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
avern1
Sep 8, 2015 06:25 PM
