smog compliance, back to square 1
Old May 17, 2016 | 10:12 AM
jakesdad's Avatar
Default smog compliance, back to square 1
Hi guys and gals.....my other thread on smog compliance help was getting old so starting fresh with a new one here.
As many of you know, I was fighting lean codes (especially 0174) and tring to get past it to get a smog check for california. Last Sunday, I was able to get the vehicle to pass a smog check by basically repetitive drive cycles and obd scans until I miraculously got it to no codes and only evap and comp monitors incomplete. Hooray!
I did not claim to have fixed the problem and it has now progressed to very rough cold idle that smooths out warm, but is still there in gear at a stop light. 0174 popping up again.
I can not find a vacuum leak. question.....when I changed the plugs and coils a couple months ago, the factory coils were denso 009700-0620. Using Rockauto reference guide,, I purchased and installed Standard Motor Product coil UF435. Can anyone tell me if the use of a product other than exact factory coil would cause a premature failure or inefficient operation, or if the UF 435 has been used by others. Ltft's at +8 this morning cold at idle, went down to almost 0 after warm up and drive around the block.
Old May 17, 2016 | 12:49 PM
Jon89's Avatar
Just like some aftermarket MAF sensors have caused problems in these cars, so have some aftermarket coils. Coil quality varies greatly, and the Chinese-made versions are probably the worst. Jaguar struggled with their S-Type coil suppliers throughout the early 2000s until they finally seemed to get it right for the 2004 / 2005 models. Many problems caused by aftermarket coils have been reported here on the forum....
DJS
May 23, 2017 04:37 PM
jakesdad
83
May 16, 2016 06:41 PM
Etobicoke sportwagon
Apr 7, 2016 03:42 PM
johns55
Apr 3, 2016 09:05 AM
Nookpad
Mar 26, 2016 11:55 PM
