SOLUTION FOR REMOVING SPEED LIMITER!
Old 05-03-2007, 05:05 PM
bigdreams05's Avatar
Default SOLUTION FOR REMOVING SPEED LIMITER!
http://www.justjagsuk.com/shopdispla...=S%2DType+ECUs
I found this site that has several S-Type ECU's from europe, where there is no speed limiter, therefore if you use any of those ECU's it should not be limited!
Old 05-04-2007, 12:02 AM
racerx82's Avatar
Default RE: SOLUTION FOR REMOVING SPEED LIMITER!
The ECU is programmed to the specific car and once you remove it and replace it may trip the security disabling the starting system. The dealer may be able to reset it but I'm not sure on that....
DpezXK8
10-28-2023 04:17 AM
PMKimpton
08-03-2019 08:22 PM
Thang Nguyen
10-12-2015 01:25 AM
AL NZ
09-04-2015 08:39 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: SOLUTION FOR REMOVING SPEED LIMITER!
