Springs, linear or progressive?
Old Oct 9, 2010 | 08:18 AM
Michael Star's Avatar
Default Springs, linear or progressive?
Does anyone know if the STR springs are linear or progressive?
Old Oct 9, 2010 | 02:08 PM
Mafioso's Avatar
I would have to say progressive or at least the eibach and H&R are.
You can tell because the coil spacing on the springs.
Old Oct 9, 2010 | 02:24 PM
thanks!
Old Oct 9, 2010 | 04:34 PM
Mafioso's Avatar
progressive-small coil spacing on the ends, larger spacing in the middle. the more weight on them the stiffer they become. As weight goes up so does the spring rate.
The higher the spring rate the stiffer the coil.
Linear-equal spacing through out the coil. retention of the spring rate through the weight range. as weight goes up springe rate remains relatively the same.
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
adam699
Oct 13, 2015 05:53 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
