str Headlight compatible with non str hid
Old Mar 5, 2013 | 03:56 PM
amgeater's Avatar
Default str Headlight compatible with non str hid
My right headlight is pointing down and doesn't adjust, Or adjust high enough. I did the screw method and it didn't work. I found a cheap replacement from an 03 which im sure wasn't an str. Would it work in my 05 str???
Old Mar 5, 2013 | 06:24 PM
Brutal's Avatar
is it HID? If so it should work, But you knowthe light should still come up high enough. does it flop around inside? It may be too broken, but you can wedge a correctly sized piece of foam btween the high beam connector and housing to hold the assembly up and more stable when theyre too broken for the screw fix
Old Mar 5, 2013 | 06:34 PM
Tee-eye's Avatar
So the 2005 facelift / exterior revisions didn't affect the headlights? (I'm curious, partly because I have a 2005 VDP with HID with the right side headlight needing the screw fix (current redneck fix with wood shim) and eventually the headlights will need to either be rebuilt or replaced. It'd be good to know what is compatible.)
One difference I've noticed between the later facelifted Rs and non-R headlights is the (mostly) decorative ring at the front of the headlight is darker on the Rs. I like that look. But if you put one non-R HID headlight assembly in one of the later Rs with the less chromey headlights, they wouldn't match, appearance-wise.
Old Mar 6, 2013 | 08:59 AM
Sslah's Avatar
i tho all STR has "black out" housing (HID) versus the regular S-TYPE?
hoodun
Nov 20, 2022 02:35 PM
Wayne Enticott
Sep 29, 2015 08:55 AM
SoCalJagS
Sep 27, 2015 09:20 AM
kevinl
Sep 24, 2015 08:25 PM
