Vent tubes? spare pare part
Old May 26, 2018 | 03:21 AM
mortenpopp's Avatar
Default Vent tubes? spare pare part
Hello everyone,
I own a jaguar s-type 3.0 V6 from 1999. Recently I have changed almost every pipes/tubes/hoses regarding the cooling system as they were leaky.
Now a new problem has emerged. The symptoms are motor stops when stopping at light signals or driving very slowly. I have located the issue to false air coming in from the hose going down on the "backside" of the engine (see pics). My guess is that the hoses are leaking like the hoses from the cooling system.
I have not been able to find a diagram showing what to find/replace when I disassemble the engine.
Anyone of you clever guys knowing what I should expect to replace and which spare part numbers I should be looking for? And if there is anything else I should replace while I am at it.
I very much appreciate your help
Morten/DK
Old May 26, 2018 | 03:28 AM
mortenpopp's Avatar
Old May 26, 2018 | 10:00 AM
NBCat's Avatar
It appears to be the breather hose underneath the lower inlet manifold. The part number is XR845730.
The upper and lower inlet manifold seals are VIN-specific when ordering.
If you haven't already done so, replace the IMT o-rings, cam cover gasket and spark plug boss seal and Bank1 spark plugs while the upper inlet manifold is removed.
Old May 26, 2018 | 10:02 AM
NBCat's Avatar
There is also a rubber connector that can perish over time and fail. The part number is C2S50039.
Old May 27, 2018 | 04:10 AM
mortenpopp's Avatar
Hi NBCat,
Thanks for all your advices... I will replace all parts you suggest
/Morten
Old Aug 14, 2018 | 08:18 AM
mortenpopp's Avatar
Hi again,
My earlier reply was not uploaded...
When I search the internet for XR845730 I get elbow hose as a result.
The elbow hose is ok... But what is coming after the elbow hose going behind the engine...?
I think it is the part coming after the elbow hose going behind the engine - the part that elbow connects to (marked with red circle on photos)
/Morten
Old Aug 14, 2018 | 01:56 PM
NBCat's Avatar
There is another elbow underneath the lower inlet manifold as well that often splits or collapses.
caldoofy
189
Apr 28, 2026 06:19 AM
caldoofy
303
Dec 2, 2022 04:18 AM
rodycam
May 23, 2017 08:07 PM
RaceDiagnostics
Apr 17, 2013 10:26 AM
OldMike
Mar 16, 2013 08:57 PM
