Weird - and different - AC problem: Rear Vent
Old Jul 24, 2015 | 12:57 PM
Warspite's Avatar
Default Weird - and different - AC problem: Rear Vent
After searching through multiple threads on the dreaded DCCV problems these models have, I may have come up with the most uncommon one:
No air whatsoever from rear console vents - regardless of settings on the control panel. Miraculously, everything else works. I get cold air on both front vents. Air properly routes per setting (defrost, foot, and dash) as selected. To me, this indicates that the DCCV and control panel are working (if it ain't broke, don't fix it....), so I'd hate to tear things apart - especially if there's just something I'm missing.
Any ideas?
Last edited by Warspite; Jul 24, 2015 at 12:57 PM. Reason: Spell Check is your Friend!
Old Jul 24, 2015 | 01:09 PM
tbird6's Avatar
Take the center console apart. I think the duct is damaged or not connected.
Has any work ever been done that involved removing the console?
Old Jul 24, 2015 | 01:34 PM
Warspite's Avatar
Console has never been removed. The only thing "done" was replacement of that single cup holder (ratty, sticky, who knows what was spilled in it... with a woodgrain one) a few months back. I rarely transport rear seat passengers, so this was the first report I received - and verified.
I'll remove it (pries up with a flat-blade screwdriver). Does that duct route directly below it, exposed?
Old Jul 27, 2015 | 02:45 PM
tbird6's Avatar
I only saw it when I installed the ACM because the plugs and wires for that are run into the center console with the flip lid. I don't think you can see the duct until the plastic cover of the console is removed.
I would check that it's hooked up and then I would run the car with the blower on high to see if the air flow problem is somewhere besides the center console. Before I put the center console back together.
With zero flow it sure sounds like something is unhooked.
Old Aug 7, 2015 | 10:57 PM
Warspite's Avatar
Nothing disconnected in the passenger cabin front what I see. I now have a shifting problem, intermittent of course (1st to 2nd, and 2nd to 3rd) and only once or 2 times a trip. This gets priority. But it's nice that the front AC vents blow cold in this 98 degree Georgia heat!
Forcedair1
Sep 8, 2025 01:57 PM
H20boy
Dec 24, 2024 03:23 PM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
dcvickers
Sep 2, 2015 06:14 PM
