Where are you guys buying the larger crank pullies for the s type r?
Old Jan 22, 2010 | 02:29 AM
qwiketz's Avatar
Default Where are you guys buying the larger crank pullies for the s type r?
Anyone have a link for this? I'd like to learn a little more about what's available for these cars.
thanks!
Old Jan 22, 2010 | 12:03 PM
tbird6's Avatar
Eurotoys has one.
http://eurotoysltd.com/catalog/produ...oducts_id=1325
Attached Thumbnails Where are you guys buying the larger crank pullies for the s type r?-lower-pulley.jpg
Old Jan 22, 2010 | 12:37 PM
qwiketz's Avatar
thanks!
Old Jan 23, 2010 | 12:24 PM
Riski's Avatar
ebay in UK......
http://cgi.ebay.co.uk/ws/eBayISAPI.d...K%3AMEWAX%3AIT
Old Jan 23, 2010 | 05:34 PM
qwiketz's Avatar
How much is shipping on something like this from the uk? I'd have to have it shipped out here and then I'd have to return my core to them also.
Old Jan 23, 2010 | 05:42 PM
qwiketz's Avatar
also, how long did it take you to install it? It doesn't seem too different than r&r any other damper.
Old Jan 23, 2010 | 06:18 PM
Riski's Avatar
Shipping is not bad....Bought things from overseas before......You can buy it out right also.....Shouldnt be too hard.....I will let you khow it is in the spring time
Old Jan 24, 2010 | 09:16 AM
tbird6's Avatar
Be very careful of the lower pulley listed that does not include moving the oil filter. There is a tiny bit of room between the belt and the oil filter. Notice the EBay add says 4.0 L engine NOT 4.2L.. All the 4.2L lower pulleys I have seen move the oil filter adapter. Has anyone installed a lower pulley on a 4.2L and NOT had to space out the oil filter adapter??
Old Jan 24, 2010 | 06:44 PM
qwiketz's Avatar
what is the stock size of the crank pulley?
Most of the fords running the eaton have at least a 7.50 crank pulley which is actually bigger than the biggest one we can buy for the jags. I'm surprised people don't go straight for the 2.75" pulley combined with our tiny crank pullies.
I don't know how close this is, but even with a 2.75 with a 7.25 crank, the formula on the kenne bell website says that max boost would be 14.3 psi with this setup. I guess that must be at the top end once the boost falls down from the peak lower in the rpm range.
Old Jan 24, 2010 | 11:51 PM
Riski's Avatar
From what I was told it is a 6" crank pulley.....and the upgrade is a 7" piulley.....
stanjag
Dec 29, 2024 08:26 PM
fast40driver
Apr 19, 2024 07:24 AM
h4wk
Nov 27, 2015 05:10 PM
Drew2006
Nov 24, 2015 11:14 AM
cheaperts
Aug 30, 2015 06:48 PM
