Yet Another Throttle Body Coolant Hose Question
Old Jan 29, 2025 | 12:21 AM
roger.neill's Avatar
Default Yet Another Throttle Body Coolant Hose Question
Howdy Folks,
This may be answered in other posts but, to be honest, I was too lazy to do a detailed search. I apologise in advance for wasting peoples' time!
I need to lift the inlet manifold to replace the TB coolant hose. The Manual says I should remove one end of the EGR tube to enable the manifold to be lifted off. I look at the rusted state of the various studs/nuts and bolts at both ends of the EGR tube and reckon I have almost zero chance of undoing them without sheering at least one off.
Here is my question:
Given the hose connects under the extreme front of the manifold, and given the EGR tube is quite long and hence should be fairly forgiving - has anybody changed the hose by simply raising the manifold sufficiently at the front end to give access for the hose change-out?
Old Feb 1, 2025 | 11:22 PM
NBCat's Avatar
And whilst in there, replace the water outlet/thermostat assembly as well if hasn't already been replaced.
Old Feb 2, 2025 | 04:08 AM
Ah, the olde 'Water Rail'. I did change that a while ago and now, of course, am regretting I didn't change the hose while I was at it. It is easy to be wise in hindsight.
John in Tennessee
Apr 11, 2022 10:21 PM
mhamilton
67
Apr 1, 2021 03:20 PM
rickpwilson
Aug 20, 2020 10:08 AM
mak567
Apr 13, 2020 11:37 AM
scottjh9
Jan 14, 2020 02:12 AM
