Hood Insulation Project Success
I wanted to replace my "rats nest" of hood/bonnet insulation to look as original as possible and cost effectively. If you've looked around some options can be quite expensive.
I paid about $50 including shipping for a fiberglass hood insulation called Metro HI1from Rock Auto. Here's an example from Amazon. Had almost enough to do two hoods. This is very similar to the OEM and I was impressed with quality and ease of the cutting to an exact fit.
Received 10,810 Likes
Received 9,028 Likes
Very nice finish. New liners make a big difference to engine bay appearance!
My old liner was seriously deteriorated and looked terrible, a new after-market liner has made a huge difference. However it is self adhesive, so the centre fasteners now become somewhat decorative. Can't see that I'll ever need to remove it though.
thedugger1 (01-22-2016)
Well I thought mine was looking pretty good, but I think you've applied the Elbow Grease even more generously, well done!!
Being such a prominent feature, the manifold shield is another make or break with detailing the XK - your looks great. Is it polished or did you paint it? I took the lazy option and sprayed mine with VHT silver engine paint to achieve a similar look.
Hi Dugger,
Your engine detail is great.
The bonnet insulation looks fantastic as well - very close to OEM look.
I used a thin gauge sheet of aluminium which is held in with the existing centre line fasteners, whilst the edges rest on the outer bonnet channels without adhesive.
The insulation is stuck to the upper side of the aluminium and so is sandwiched between said aluminuim and the underside of the bonnet.
I'm happy with mine, but yours looks way better.
Nigel
Nigel
I polished the manifold heat shield, not painted as follows:
600 grit sandpaper on corroded spots
Moved to 1000 grit
Moved to 0000 steel wool dipped in Motorwerx Metal Polish (I'm sure most brands would be fine)
Attached a mini-buffer to my drill (the one that comes in those headlight repair kits) and buffed with the metal polish. Probably about 3 passes.
I did sand and paint the bolts that attach with high heat paint
It's crazy how these modern engines with their plastic covers are so simple in comparison. This XK motor is just so pretty, it's worth it!!
NOTE: I removed the heat shield prior to doing this. 1 minute job with plenty of WD40 on those bolts prior.
I'm now trying to do the same on the cat converter.
P.S. Nigel, that's a pretty slick solution you found as well. Has a cool custom, but not TOO custom look.
Moved to 1000 grit
The following 2 users liked this post by thedugger1:
Jag-o-nomic (01-23-2016),
XJ6Paul (01-24-2016)
Received 2,399 Likes
1. The boot insulation on my car resembled a "moth eaten bear rug". Phrase not coined by me, but an apt description. I removed it. A bit of a tussle with the press on clips working upside down. Saved 'em, why, I dunno. I tried to polish the paint. No go. unstained, but dull, as the color coat before clear. One day, I will spray it with "bed liner" paint. If it had any heat or sound insulation qualities, I don't miss them.
2. When the DOHC was removed, I cleaned up the bay a bit. Oven cleaner of the inch thick grunge on the front cross member. I found a can of Duplicolor that was close to Grosvenor brown and sprayed parts of the inner wings. and, a bit of aluminum paint on the fire will insulation. Black paint on more of the black tin. The lump that went in was clean. More than decent. The lump came with a big triangular
intake sound deadener. Looked like an engine cover. Deleted. And the PCM is in a nice ribbed aluminum housing. too nice to hide. I made straps to attach to the wing braces and suspended the PCM from them. always had a weakness for ribbed alloy!!!
Jaguar was out on errands yesterday, purring.
Carl
Carl
Received 9,006 Likes
Engine covers, oh yeah.
I've done a couple of small tasks on my daughters VW PASSAT AWD V6.
Covers laced together cover the entire engine bay. Why?
I don't know. a quarter released the hold down screws, sorta like the Dzus of old.
I nice Hemi headed DOHC V6. Why hide it ?
I was tempted to dump the plastic. but, not my car, so I out it back on.
Does it have an engineering reason. air flow of some type?
Protect the hood from engine heat. contain engine noises?
I don't know.
Carl
I don't know.
Carl
Thank you!
WTB[SouthWest]: wanted XJS Euro headlight bezels,chrome
ronbros
01-24-2016 05:54 PM
djpxk8
01-22-2016 11:10 AM
WTB[Western US]: WANTED- Crankshaft damper/pulley for 94 XJ12 6.0
XJsc-guy
01-20-2016 01:16 PM
