WANTED: '96 XJS A/C Fan Knob, A/C Slider knob, Tiny A/C Bulbs.
WantedInterior/Upholstery
Description:
Hi. Due to my extreme stupidity I need a replacement A/C Fan knob for my '96 XJS. This has a little fan symbol on it. I also need the rectangular knob for the A/C slider located just above the radio. And I need at least two of the little tiny bulbs that light up the A/C controls on this. It's OK if these are burned out! I've learned how to replace the bulb itself using the old base, but I am missing two of the old bases, so I can use burned out ones. Any help is appreciated.
Received 12,769 Likes
I was able to get a brand new slider knob from Jaguar & Land Rover Classic Parts: parts@jaguarlandroverclassic.com
5 pounds, plus 16 pounds shipping!
The fan knob was harder, finally found it at a place called Jaguar Heaven: 1st.jaguarheaven@gmail.com
It was $50, making me feel Even Stupider about losing the original.
The bulbs I got from GoorgenPalang on ebay. Remember I needed the base as well as the bulb itself. Also for full bulb with base, this page MIGHT have been useful; https://www.jkllamps.com/automotive/vintagecar
I didn't actually buy from here but I love that they have detailed pdf specs showing exactly what the dimensions of the bulb and base are.
As far as replacing burnt out bulbs I was able to do that by using "CEC Industries #8111 Bulbs, 14 V, 0.91 W, Wire Terminal Base, T-1 shape" and my old base.
Hope this helps; good luck.
-mB
-mB
