gas tank problems
Old 05-06-2024, 11:02 AM
Luis Tomas's Avatar
Angry gas tank problems
Every time I put gas in, say 96 octane, when I open the gas cap, gases come out that sound like when you uncap a Coke. If it does that, is it because something is clogged or is that normal? One day it got so hot that the gasoline rose and was moving.or any gas valve to buy?
Old 05-06-2024, 12:21 PM
Vee's Avatar
Vee
Vee is online now
Received 1,519 Likes on 1,181 Posts
Most likely, the Rochester Valve by the charcoal canister has clogged. It is located in front of the drivers side front wheel.
There is no good substitute for it. I would recommend removing the Rochester valve entirely to see if this symptom Goes away. If it does, you found the problem; if not, come back and update us please.
Old 05-06-2024, 04:14 PM
Luis Tomas's Avatar
Could you provide me with a photo or a video of how to remove it because the last time it scared me because the gasoline almost came out of the tank.
Old 05-06-2024, 07:35 PM
Vee's Avatar
Vee
Vee is online now
You can search for a past post of mine. The title uses the word, “whoosh”.
That should get you started on what’s going on.
It’s the vent line for your fuel tank. If there’s any fuel in there, it shouldn’t be enough to scare you. Just make sure you open the fuel tank cap to repressurize your system when you remove it.
Old 05-07-2024, 09:18 AM
Greg in France's Avatar
Received 9,143 Likes on 5,378 Posts
Vee
Have you cured the whoosh?
Old 05-08-2024, 07:04 AM
Vee's Avatar
Vee
Vee is online now
@Greg in France Yes, the whoosh has been resolved....but the smell continues in the trunk. The mat has been saturated in, what I think, can only be fuel.
Not sure how its getting there, as I did refurbish the tank about two years ago.
The following 2 users liked this post by Vee:
Greg in France (05-08-2024), JJS- Florida (05-09-2024)
10 XF Premium
05-10-2024 12:32 PM
themacs
01-18-2014 03:56 PM
Fezz
11-30-2013 05:00 PM
pan84
11-19-2011 08:41 PM
Quick Reply: gas tank problems
