Jaguar xf towbar wiring
Old Jun 24, 2024 | 02:42 PM
Cordwell1518's Avatar
Default Jaguar xf towbar wiring
Hi,
I have a writter towbar already installed on my car but need help with connecting up the electrics 🤔 if anyone knows??
It's a 2013 xf s and I have purchased this: Towing Bypass Interface Relay PCT Logicon ZR2500 7 Way Universal
Which is apparently the correct module for my car but am not sure what wires control the brakes, left and right indicators and reverse.
Had anyone fitted one of these and knows what to do please?
Old Jun 24, 2024 | 03:25 PM
sportbrake_phil's Avatar
Check the box you have is solid state with low input current - if it drives relays from the lighting circuits the feedback current from the relay coils is very likely to kill the outputs on your RSJB.
I believe the wiring colours on the top left connector of the RSJB are:-
Violet-Orange - Right Stop
Grey-Brown - Left Stop
Green-Brown - Reverse
Grey-Orange - Left Indicator
Green-Orange - Right Indicator
White-Orange - Right sidelight
Violet-Green - Left Sidelight
Old Jun 24, 2024 | 04:22 PM
Hi mate thanks for your reply 👋🏻
These below are the colours I have going into the the rear lights, should I not connect near the lights themselves and go near the RSJB? Do you know where abouts that is please?
RH tail light Violet and brownGreen and orangeWhite and orange BlackGreen and brown LH tail light
Violet and greenBlackgreen and brownGrey and orangeGrey and brown
Honestly appreciate your help as I'm due to collect the caravan this Friday
Old Jun 24, 2024 | 04:30 PM
I found these drawings aswell but just trying to make head or tail of it 🤔
Old Jun 24, 2024 | 05:20 PM
It doesn't matter where along the wires you connect, it's possibly easier near the RSJB, as they're all together, and it's inside the car, if you connect outside immediately behind the light clusters, you have to deal with water proofing, and feeding / sealing the wires through the grommets into the interior ( presuming that's where you'll be putting your new module ).
The RSJB ( rear smart junction box ), otherwise know as BCMB ( Body control module B ), Rear junction box (RJB) and Auxiliary junction box(AJB) ( why do they need four names and acronyms for everything ), is the "fusebox" on the right side of the boot/loadspace. It's actually a computer that happens to have a few fuses fitted. There's a pull-out door on the sportbrake if you look carefully, and I believe you have to pull the carpet type lining out on the saloon ( held in by a few push clips. ).
Good luck, and please let us know how it goes.
It looks like:-
https://www.jaginfo.org/cdn-cgi/imag...ox-png.181717/
Old Jun 25, 2024 | 02:33 PM
It looks like:-
Sport brake phil!! You are an absolute legend that done the job perfectly 😎.
It was exactly what you said and I connected it all at the plug on the top left of the car smart fuse board thingy.
Job done.
​​​​​​Honestly thanks mate for your help!!
Old Jun 25, 2024 | 05:14 PM
Thanks for the update, I'm glad to hear you're all sorted in time to pick your caravan up.
Old Today | 10:06 AM
Dsportjones's Avatar
Did this work after? Having trouble with mine and the exact same logicon kit
Old Today | 10:13 AM
Hi mate,
Yes it did worked a treat 😀
I just used the scotch locks clips on the wires, I think mine was different on just one wire colour but that was it.
I honestly can't remember as it was so long ago but I remember it being easy thanks to Phil's help
Update:
My partner just told me I think it was purple or brown where the other way as they looked very similar colour
And I connected into the wiring in the loom near the spare tyre, if you open it up you will be able to see the colours there to the right of the spare tyre
Old Today | 01:42 PM
is there anychance you can take some photos for me please as ive connected it all up and my immobiliser has kicked me out and the car wouldnt start until i took it all back off, thanks conor
Old Today | 01:49 PM
Unfortunately I don't have the car anymore 🤔
If you send some pictures of what you have done or the loom where you are connecting into and I'll try to remember from memory mate and let you know if that helps
Noma Auto Parts
Jun 6, 2023 04:27 PM
ademler mustafa
XF (X260)
Jul 23, 2022 03:27 AM
Nick Cowger
Apr 24, 2019 09:16 PM
Jaggs1980
XF (X260)
Feb 25, 2018 09:00 AM
LiamsJag
May 23, 2017 03:18 AM
