Key Fob Replacement for 2007 Jaguar XK
With your 2007 you need to choose a fob based on your VIN. Part way through the model year the fob technology changed (IIRC, from single frequency to dual frequency), so if you get the wrong type, it won’t work with your car.
Search this forum, you’ll find the VIN split so you can get the right type.
Even if you get the correct type of Smartkey (single channel or multi channel) and it works to unlock/lock your doors/trunk, it still might not work in the center console emergency slot. If that happens, you could have a problem.
IMPORTANT! Read this entire thread:
https://www.jaguarforums.com/forum/x...e-port-178216/
The Jaguar X150 Smartkey is a diabolical digital vault that was designed to stop car thieves who could use an inexpensive "black box" to quickly and easily clone a key and drive the car away.
That key must also be able to be accepted by the emergency slot in the center console and automatically eject when pressed down.
Stuart
Stuart
MBary
Sep 11, 2025 03:26 PM
Currently Active Users Viewing This Thread: 9 (1 members and 8 guests)
