Bearing replacement XK8
Old Apr 14, 2026 | 12:24 PM
multiplecats's Avatar
Default Bearing replacement XK8
Hi all,
Just getting ready to press in a new front wheel bearing for my XK8. I've heard about the trick of cooling the bearing in a freezer for a few hours to assist, but is there any advantage in adding a thin coating of oil or Moly grease to the inside of the Hub beforehand? Kind of thinking any lubricant might be pushed out under extreme pressure.
Thanks, Andrew.
Old Apr 15, 2026 | 10:13 AM
clubairth1's Avatar
Community Influencer
Heating and/or cooling is fine. I never use lube on any press fit parts unless the instructions say to. Clean and aligned properly. It's suppose to fit tight.
Old Apr 15, 2026 | 10:50 AM
RoverJoe's Avatar
I always clean and lightly lube the surfaces on press fit bearings like that, if it actually helps, I don't know, but it makes me feel better about it.
The grease can't hurt, it's mostly going to get squeezed out anyway. The interference fit of the metal will still hold it. I just don't want any chance for it to bind or get cocked at an angle while pressing and cause damage.
Old Apr 20, 2026 | 07:36 PM
RRpip's Avatar
Skip the oil or grease. It won’t help with pressing just gets squeezed out and can trap dirt or cause the bearing to seat unevenly. Freeze the bearing, heat the hub slightly with a heat gun if you want, then press dry. Clean metal on metal is best.
Old Apr 20, 2026 | 08:26 PM
Don B's Avatar
Hi Andrew,
I have moved your thread from the General Tech forum to the forum for the X100, which is where you will find knowledgeable owners of similar cars.
As others have said, the bearing should be installed clean and dry, aside from the condensation that will form due to being kept in the freezer until just prior to insertion into the vertical link. Same for the wheel hub (freeze it too). And don't forget the circlips!
Don
Old Today | 12:32 PM
Thanks everybody. Gave the bearing an overnight session in the freezer but no lube, pressed in fine. Onward now to press in the hub!
Aleather
Jul 27, 2021 08:15 AM
liquidreality
Sep 9, 2014 08:08 PM
scardini1
Feb 20, 2014 10:09 AM
2meke
Jul 2, 2013 03:36 PM
xenophobe
Mar 25, 2013 08:12 AM
