'02 X-Type 2.5L is shocking at 1500-1700 RPM
Hello everyone,
I have an automatic 2002 X-Type 2.5L V6, and every time when I drive around 70 km/h (1500-1700 RPM), the car shocks pretty hard.
It happens when the car is in the 5th gear, and only around that RPM. When I put the car in the 4th gear (2200-2500 RPM), it drives perfectly fine. When I drive faster (higher RPM), it also drives well.
Does anyone have an idea what could fix it?
Thanks!
Thanks!
I think, we need a better description of what the issue is....
What's the mileage?
Did you ever do an ATF change (Automatic transmission fluid)?
If though: Which ATF did you use?
What's the mileage?
The car has done 255.00 KM’s I have bought the car around a month ago and have never done a ATF change, I also dont think anyone has ever done one, but I can check it
