'02 X-Type 2.5L is shocking at 1500-1700 RPM
Old Apr 21, 2026 | 10:29 AM
Jhonny's Avatar
Default '02 X-Type 2.5L is shocking at 1500-1700 RPM
Hello everyone,
I have an automatic 2002 X-Type 2.5L V6, and every time when I drive around 70 km/h (1500-1700 RPM), the car shocks pretty hard.
It happens when the car is in the 5th gear, and only around that RPM. When I put the car in the 4th gear (2200-2500 RPM), it drives perfectly fine. When I drive faster (higher RPM), it also drives well.
Does anyone have an idea what could fix it?
Thanks!
Old Apr 21, 2026 | 06:14 PM
Peter_of_Australia's Avatar
I think, we need a better description of what the issue is....
What's the mileage?
Did you ever do an ATF change (Automatic transmission fluid)?
If though: Which ATF did you use?
Old Apr 22, 2026 | 07:41 AM
Jhonny's Avatar
What's the mileage?
The car has done 255.00 KM’s I have bought the car around a month ago and have never done a ATF change, I also dont think anyone has ever done one, but I can check it
Old Apr 22, 2026 | 09:01 PM
I still do not know exactly, what this means:
255,000km is a lot without ATF change. At this mileage the debate starts, if it is absolutely due now, or if it is simply too late already, as there are dirt deposits in the mechanics of the transmission (in the little shifter pistons), which will move during an ATF change and inhibit proper function. Some say, just leave it, until the transmission dies - and maybe that is what happened on your car already...
XK8FAN
Dec 5, 2024 02:41 PM
skidman
Dec 20, 2022 10:42 AM
Roighru
Mar 5, 2022 08:15 AM
Camwad
Sep 5, 2021 12:16 AM
