2003 heater hose leak
Old Yesterday | 04:43 PM
Pantera928's Avatar
Default 2003 heater hose leak
There is a hose that looks to be a heater hose near the right side O2 sensor in the photo that is leaking at the joint to a hard pipe. I am not sure hw this is clamped to the pipe but am wondering if there is a solution other than replacing the heater hose which looks to have multiple sections and is probably quite expensive.
Can I somehow remove the existing clamp and use a regular hose clamp? Not sure how this existing clamp even works
I am sure others have dealt with this before.
Old Today | 05:18 AM
giandanielxk8's Avatar
That is the infamous octopus heater hose. That's a normal clip. Yes, you can cut that out and replace with a regular clamp. I would still do the hose because it's likely on it's way out.
The hose part number is: MJA6728AC
OEM is $355, aftermarket is $270 on SNG Baratt. A silicone hose replacement is available from Swallow's Racing for £172.
Old Today | 06:46 AM
michaelh's Avatar
^^ +1
Consider also replacing the valley hoses, although that's a bigger job
Old Today | 07:31 AM
Pantera928's Avatar
Thanks @giandanielxk8 Now to figure out how to remove the existing clamp and so I can put on a regular hose clamp temporarily to move the car.
I ordered a new hose but need a temporary fix.
@michaelh Not sure what a valley hose is nor what is needed to replace them. Care to educate me? THanks
Biff Baxter
Nov 5, 2024 09:50 AM
AlexJag
Jul 3, 2024 12:34 PM
rumm5
Feb 2, 2022 05:30 PM
David Dougherty
Mar 16, 2020 09:32 PM
