need heater hose part # C2P2186, not available anywhere
2007 Jaguar XKR. There is a coolant leak at the end of the heater hose that goes into the firewall. The leak is engine side. There is a part C2P2186 for the whole heater hose/pipe that Jaguar no longer makes and it is unavailable. I may call a salvage yard to see what they have but what I need is just the plastic connector/elbow at the end of the hose (picture attached). Where the connector in the picture is broken at the top, it turns about 90 degrees and runs for maybe one inch as just a straight pipe, nothing fancy on the end. Does anybody know if you can buy this part separately, and if so, what is the part number?
McJag222 Yes, I think that is it. Thank you very much. Yesterday I rigged up a solution with a copper elbow from the hardware store but I would prefer to have the correct part. Thanks again.
