Oil Pressure Sender Unit Jaguar MK2 1962
Old Today | 04:52 AM
GGJag's Avatar
Default Oil Pressure Sender Unit Jaguar MK2 1962
Hi to alls
Does anyone recognize this type of oil pressure sensor on a 1962 Jaguar MK2?
I have a leak at this sensor and need to replace it.
However, I can’t seem to find this model
Can I use a standard model available from regular suppliers given that the question on the thread ?
My best regards
Gérard
Old Today | 07:00 AM
cdg66mk2's Avatar
I have never seen that type of sender. Assuming that someone did not ruin the threads installing the mystery sender, the standard Jaguar type should work.
The thread on the correct sender (and the matching filter housing, of course) is a fairly unusual British straight pipe thread. It is not a tapered thread and it is not 1/2-20 even though the latter will thread in a few turns before seizing.
Since it is not a pipe thread, the copper washer is critical for sealing.
Old Today | 12:02 PM
timsdad's Avatar
I put a new oil pressure switch on my '66 S Type a couple of years ago and it was a BSP parallel thread. I got a replacement switch from my local motor factor and it works fine.
Ray
JagZwahlen
Mar 23, 2026 02:04 PM
MilesDiNardo
May 29, 2024 07:32 PM
David F.
Apr 30, 2018 02:22 PM
RaceDiagnostics
Feb 8, 2015 12:07 PM
manderson10
Jan 3, 2009 08:07 AM
