No crank Where is Relay 10 Located?
Old May 16, 2026 | 05:17 PM
INSLTRCR's Avatar
Default No crank Where is Relay 10 Located?
2008
XKR 4.2
Convertible
After battery change and several drives and Re-Learns intermittently it will not crank. Only fix I have figured out is battery disconnect and wait, do the relearn sequence and then its fine for a few drives/starts. So I dove into Service Manual and Starter circuit shows its activating Relay10 directly to the starter. I checked all 3 Fuse Boxes and none have a Relay 10 spot. Ive seen many 1,2,3, 4 and even an 8 but no R10. I really want to wire in a momentary switch for this for the next time so I dont have to strip the trunk and relearn all over again.
Old May 16, 2026 | 07:00 PM
guy's Avatar
guy
That’s an interesting situation. May we see what codes you’re throwing before the reset?
Old May 16, 2026 | 08:21 PM
INSLTRCR's Avatar
Default 08 XKR Convertible
I cleared them all, inst cluster comm failure code seems to be very regular, but inst cluster has NEVER not functioned. It shows everything its supposed to (lites, gauges, warnings, low key batt, clock etc), . But I've had that same code for years because the steering colum does not lock so that code is there regularly also and neither can be cleared with my D7 scan tool.
Only strange think is my scanner shows brake switch being depressed/actuated on or off. So I know bcm is seeing brake depression, but when its acting up and I depress and press to start it does not show bcm requesting start/crank.
I'd really rather just put in a momentary switch to jump the start solenoid rather than chasing down the rabbit hole on why it needs a battery reset so often.
3rd time in as many uses.
Dan
08 XKR
Convertible
Old May 16, 2026 | 08:23 PM
INSLTRCR's Avatar
I'll write them down next time it happens. I just so PO'd the last time I just wanted to start and leave that location.
Old May 16, 2026 | 08:26 PM
INSLTRCR's Avatar
Thanks for the reply, just very frustrating to an old wrench.
Old May 18, 2026 | 06:14 PM
guy's Avatar
guy
I'm sure you're aware that the very first pinpoint test is confirm the battery health. Simplest wat is a voltage reading 6 hours after any charging event (ie car running or maintainer attached)
Old May 18, 2026 | 06:43 PM
Sean W's Avatar
is probably located on the underside of the engine compartment fuse box.
https://www.jaguarforums.com/forum/x...-relay-292856/
Old May 24, 2026 | 09:09 PM
INSLTRCR's Avatar
12.6v at the battery. New Charged and installed when it acted up. But Thank you.
Old May 24, 2026 | 09:11 PM
INSLTRCR's Avatar
Sean;
I saw a photo of the bottom of the PDB (on here I think) and it looked like it was just plug-in connector packs , but I will give it a look see. Thanks.
Old Yesterday | 06:49 AM
guy's Avatar
guy
We’re in the dark without knowing the complete set of codes thrown. The work around doesn’t solve the root problem.
Old Yesterday | 09:43 AM
HealeyJag's Avatar
So..
The car goes into "lock out" mode with the lights flashing?
Hard restart and she is fine?
Had same issue..
Replace FOB battery and only ooen car when u are next to it. No 20 ft opening..
Randyp
Apr 14, 2025 06:43 PM
Michael MJ
May 24, 2022 01:14 PM
olivermarks
XJ XJ12 ( X305 )
41
Mar 26, 2021 05:12 PM
Rob Benjamin
Nov 7, 2020 01:27 AM
Darrenmb
Sep 22, 2015 09:45 AM
