Voltage Regulator
Old Jun 11, 2026 | 03:34 PM
Rishi's Avatar
Default Voltage Regulator
So I was driving at night and it was raining so I had headlights on, wipers on and the fan running. Suddenly the ignition light came on and the ammeter indicated that we were now discharging. This remained the same all the way home even driving on the motorway at 2500rpm. This is not the first time this has happened. Usually the next morning all is fine. At one point I did replace the control box with an aftermarket RB340.
My car is positive earth and still has a dynamo. As it is the 3.8 should I have a 30 amp RB340 and are the regulators different for positive and negative earth?
Old Jun 11, 2026 | 04:30 PM
Jose's Avatar
I don't think so, they are just re-polarized for either Pos+.or Neg- ground.
Old Jun 11, 2026 | 05:14 PM
Peter3442's Avatar
Mk2 3.8 '64 Dynamo not charging when engine hot - Jaguar Forums - Jaguar Enthusiasts Forum https://share.google/iLpbLIc2HI37APwCO
Rather than repeat what's been discussed before, I'll point you to the link above. It's not an uncommon problem and usually not anything complicated to fix. However, it may be a long process of checking and cleaning connections and contacts. Also, modern mechanics don't have the first idea about adjusting a mechanical control box though it's well described in the workshop manuals
Old Yesterday | 01:14 PM
Rishi's Avatar
When I disconnected the D terminal the wire separated from the spade connector with very little effort. It was corroded through even though the wiring loom is still pretty new. Anyway there is a thick and a thin wire connected to the D terminal. I stripped them back, tined them properly, clamped them back in the spade connector and the soldered the wires to the connector. After that the ignition light went out and all seems well. We will see!
434MHz
23
Apr 16, 2026 04:42 AM
carlstev
Jun 23, 2021 04:24 PM
avt007
Jan 13, 2017 01:11 PM
JBGROSS
Nov 30, 2016 06:24 PM
jamest
XK120 XK140 XK150
Jun 19, 2014 01:01 PM
