X308 new part numbers participation thread
Good day folks, I thought this to be an important thread for our gals have had some part #'s redone and a thread of updated ones in one location would be helpful to the community. If you have OEM or aftermarket part numbers that have changed, it'd be appreciated to provide such.
To start with, Denso, they have very few parts available anymore, but these are kind of important. What is cool about Denso is you can order online from them or they will direct you to local shops that carry their products. If you do your own search, you'll probably wind up on their main site... https://www.densoautoparts.com/. That, even though it says you can purchase directly, it doesn't do anything when you prompt it unless you are looking at the part itself. Plus, it only shows the stores who sell Denso, it doesn't necessarily mean they have that part. This site states they are not Denso...DensoProducts.com: Denso Auto Parts Online
As noted, they only carry a couple critical parts we need anymore. But you can also get the new reference number and do a web search for cross referencing for the old part #'s don't cross reference well anymore either.For example, for my 2000 VDP, the MAF number is LNE1620BB Denso...that number is no longer available or good to reference, the reference on the main Denso site is now Denso 197-6040. You will find this same issue with O2 sensors, fuel pump(s) and the alternator (reman'd).
Let's add spark plugs, NGK is the OEM plug and with all the advancements there are not only changes but more options in case the specified ones (NGK PFR6G-13E) aren't available...https://ngksparkplugs.com/en/
They carry other option-able plugs and also carry O2 and water temp sensors, coil packs and boots
This is a 3rd party site that references a link to the NGK site at the top...https://www.ngk.com/ngk-parts (the link is for a 2000 VDP SC so be sure to reference your model). Thecommended gap (0.40")
They also carry other option-able plugs and also carry O2 and water temp sensors, coil packs and boots.
How to recognize fake NGK. She has a thick Indian accent, but you can stop the vid and read the examples she is showing in the sub-pics....
