aron
Old Jul 8, 2018 | 01:35 PM
aron's Avatar
Default aron
engine problems or turbohi i got jaguar XF LUXURY V6 2.7d i was driving today at motarway and the power gone to half and make noise at engine ang got little oil leak and smoke at engine some one told me engine is broke but the car drive fine just is that noise do you think is tube turbo is broke
Old Jul 16, 2018 | 05:16 AM
Welcome to the forum Aron,
I see you have also posted in Diesel variants forum about this issue. Even for diesel versions, the best response is usually obtained by posting in the X250 model forum (https://www.jaguarforums.com/forum/xf-xfr-x250-44/).
Strange (and perhaps lucky!) that the car is still driving fine. The symptoms are likely to have set error codes which will help diagnose the cause. Before jumping to expensive conclusions such as a failed turbo, having the codes read should help you to determine what has happened.
