How to actually update Maps for Xtype
Old 02-25-2013, 12:05 PM
mgwanderer's Avatar
Question How to actually update Maps for Xtype
What is the exact procedure to update the maps, I have a disc from a friend but what is the procedure???
Ignition on / off
Do I push any buttons etc etc
Old 03-03-2013, 01:25 PM
VFouR's Avatar
You need to have the ignition on so that the navscreen is operational.
Go to the boot & eject the current disc, then load in the new disc.
Any software updates will start automatically.
DO NOT switch off the ignition until the updates complete. You'll see flashing 51 & 50 (or is it 52?) on the outside temp display while the nav screen is black. Whatever you do, DO NOT PANIC, and don't switch off the ignition!
The update can take up to 10 minutes or more. Once it's done the nav screen should come back on & you'll have lost all your stored addresses and previous destinations. You'll also have to re-set your home address, search by country etc.
That's what I did and it worked fine...
Paora
02-04-2021 12:36 AM
Finbarr1975
10-04-2015 05:32 PM
Newark Nj Gang
10-02-2015 02:39 PM
GoNavyMike
09-28-2015 08:56 AM
Quick Reply: How to actually update Maps for Xtype
