XF 3.0D S Restricted Performance
Old Jul 21, 2017 | 06:54 AM
Nigelw67's Avatar
Default XF 3.0D S Restricted Performance
Hi All,
Has anyone seen the following fault codes after the dreaded restricted performance warning? Local Jag independent is sure its a turbo actuator. Main dealer suggesting further diagnostics in case its an induction air leak. Key question is has anyone seen the exact same combination of codes and what was the fix?
P008D MAF A
P0235 Turbo boost sensor A
P22D2 Turbo inlet valve stuck open
P22CF Turbo inlet valve mech fail
Thanks,
Nigel
Old Jul 23, 2017 | 03:29 AM
PsiFox's Avatar
Hi,
You'll get a better response if you post your question in the model specific section.
