XJ6 3.2 x300....oil?
Old Apr 10, 2017 | 06:00 AM
Nigel192's Avatar
Default XJ6 3.2 x300....oil?
I have a 3.2L x300 XJ6 1996/7... what engine oil should I use? I see Costco has Mobil 1 0w -40 and Castrol Edge 0W-30, 5W-30 and 5W-40. Any help would be great.
Old Apr 10, 2017 | 06:24 AM
drmike's Avatar
I have used Castrol GTX 10-40, Shell Helix HX7 10-40 and Eurocarparts own brand Triple QX 10-40. The last one was really cheap when on special offer. I checked all the specifications and each of them seemed to be a good match so I buy on price. People can be snooty about EuroCarParts stuff but they are made to spec by a well established company whose name I can't recall.
Look on the X300 forum and settle down for a good, long read
Mike
Old Apr 10, 2017 | 07:53 AM
SteveSheldon's Avatar
+1 on Europarts Triple QX.. from time to time you get discounts or 2 for 1 on the oil, and it is pretty much the same spec as more expensive oils.. I have run an X-Tyupe and 2 X308s on it without issue.
Old Apr 10, 2017 | 09:11 AM
Mikey's Avatar
Your car doesn't need and won't benefit at all from synthetic oil. I'd use conventional oil and choose the viscosity recommended by Jag in the owners manual.
Old Apr 10, 2017 | 10:02 AM
Originally Posted by Nigel192
I have a 3.2L x300 XJ6 1996/7... ......
Welcome to the forum Nigel192,
Old Apr 10, 2017 | 11:58 AM
Nigel192's Avatar
Thanks Graham, I have posted a few lines as requested as an intro.... hope it worked as I am not computer literate.
Old Mar 26, 2018 | 05:55 PM
Jagguyx300's Avatar
Hi there, I’ve always used Castrol magnatec 10w40, was told by independent jaguar specialists that’s it’s the best for this engine, not overly expensive if on offer either.
