US Lower Atlantic NC SC FL GA
anyone able to reprogram my 03 s-type R in south florida?
Old Dec 13, 2014 | 08:04 PM
vilemd's Avatar
Default anyone able to reprogram my 03 s-type R in south florida?
just got my first jag. 03 stype R. pretty fun car to drive, scary fast. fixing it up myself as I work on cars, dousnt need much but has a problem with the trans I keep hearing is actually a softwear issue from jag. there is a service bulletin and says just to reboot system with newest softwear but im trying to not spend over 150 dollars just to have the program run which takes less then 15 minutes.
if anyone is in south florida the can help me out that would be great
problem= the vehicle shifts kind of hard but main problem is hard shift from 2-1 gear when slowing down. sometimes there is a slip on the way up but not all the time
there is a bulletin below that shows recommended computer reboot. might or might not take care of problem but i can offer you 50 dollars and come to your location. usually takes 10 minutes to run program. iv had it done on cars before and I can come to you because I know time is a factor. im in west palm beach
here is the info
BMW TSB - SIB240305 bulletin:
SUBJECt= Harsh 2-1 Downshift
MODEL= E60 (545i); E63/64 645(Ci/Cic) with 6HP26 up to 04/05
SITUATION= Customer may complain of the following:
An excessively harsh 2-1 downshift when decelerating to a stop, or
Transmission "bangs" into gear when accelerating from a full or a "rolling" stop
(vehicle did not come to a complete stop).
CAUSE= EGS software.
CORRECTION= On a customer complaint basis only, reprogram/recode complete vehicle using SSS
with CIP on-line update 17.01, or higher.
Important:
Transmission temperature must remain below 50 deg C and trans shifter must be
placed in P position prior to the start of CIP programming.
TSB S307-10Owners of some 2003 MY S-TYPE vehicles, within the VIN range M44998-M81000, may experience the following issues:
  • Transmission Malfunction Indicator Lamp (MIL) illuminating and Diagnostic Trouble
  • Code (DTC)P0606 logged.
  • Transmission hesitating and then thumping into gear from 2 – 1..
  • Transmission judder in second gear.
To eliminate these issues,the Transmission Control Module (TCM) should be
reprogrammed using the Worldwide Diagnostic System (WDS) with software release JTP 759/23 or later
Old Jan 18, 2015 | 10:54 AM
Drinkwine47's Avatar
Default re-program
I just did it (for the same issue) and it works
disconnet the battery terminals
click them together
leave them apart for a half hour
re-connet them
the computer is back to the factory settings (default)
and will start learning driving habits re: Accelerasion, braking, slowing down and re-reaccelerating, etc.
Sounds to simple to be true, but, it worked for me
good luck
chris p
p.s. A jaguar dealer's service advisor told me to do this
Old Jan 18, 2015 | 12:18 PM
Mikey's Avatar
The condition you're referring to is commonly called 'the lurch'. The factory fix worked on some but not all cars. Didn't work on mine.
The trick suggested by Chris will work for a short while until the transmission learns bad habits again.
Clare Jennings
Oct 4, 2015 05:43 PM
3jagfamily
Oct 1, 2015 01:49 AM
