US Lower Atlantic NC SC FL GA
Headlight Polishing Ft Lauderdale
Old Oct 10, 2015 | 07:35 AM
oncapanthera's Avatar
Default Headlight Polishing Ft Lauderdale
Can anyone recommend a headlight polisher in/near Ft Lauderdale?
Old Nov 13, 2015 | 10:45 PM
kobedog1's Avatar
It is so very easy to do this yourself, depending on the degree of fading and buildup there is on your lights. If they are just slightly opaqued, use a little wax with a fine kitchen scuffing pad. A little elbow grease should do the job.
For the really faded lenses, buy a headlight restore kit at the auto parts store. Buy a brand like McGuires that has the sanding disks with it. You will be basically "wet sanding" the lenses with fine grit paper, then polishing with a wax. Amazing how well this works.
A little work and they will look good as new!
Vtjaguarlover
Dec 6, 2015 04:09 PM
danke
Oct 5, 2015 11:04 PM
cash5ive
Oct 4, 2015 11:41 AM
Tcjjsek
Oct 4, 2015 05:01 AM
kevinl
Sep 24, 2015 08:25 PM
