US Northeast ME, NH, VT, MA, RI, CT, NJ, NY, PA
2004 drivers side headlamp not working on low beam standard lights,
Old Sep 25, 2019 | 05:43 PM
otrnut's Avatar
Default 2004 drivers side headlamp not working on low beam standard lights,
need some help with finding out why my driver side standard low beam headlight does not work ,not sure which Fues it is in engine compartment as fuses ar are marked or numbered in any way
Old Sep 25, 2019 | 06:14 PM
jackra_1's Avatar
Providing specific details of your car would help.
Old Sep 25, 2019 | 06:34 PM
otrnut's Avatar
2004 xj8 standard headlights . looked into engine compartment fuse box and nothing is numbered or labeled
Old Sep 25, 2019 | 07:43 PM
jackra_1's Avatar
You need a handbook for your car that shows all the fuses or the electrical wiring diagrams which I think can be found in this forum.
https://www.jaguarforums.com/forum/x...ownload-10582/
Look in the above thread.
Another possibility are the grounds located near the headlights. If not properly grounded due to corrosion they can cause issues. They break easily so be careful if you look at those grounding studs.
Whatcher3
May 1, 2019 06:57 PM
Kyd
16
Jul 3, 2016 09:58 AM
cybercg
Sep 30, 2013 03:43 PM
Tomcat
May 14, 2008 08:09 PM
