US Southwest AZ, TX, NM, OK
Inactive suspension 2011 XF
Old Apr 23, 2021 | 10:02 AM
7thward's Avatar
Default Inactive suspension 2011 XF
Hello I’m from Tx and have a 2011 XF supercharged. That needs some work done. I had a coolant leak coming inside the car under the carpet and came to find out it was the heater core connectors leaking. After removing the dash to see where the leak was coming from. I just went on an replace the heater core, txv, & evap so that should not be a problem anytime soon. Next was the control arms lower/upper & forward was replace. And now I’m getting an inactive suspension on my scanner tool. I check fuse ( good) can not find a relay chart. Check the wires/ voltage to shocks connector an nothing is out. I also check the adaptive module voltage 14v going in and 2-5 coming out. I need help!!
Old Apr 23, 2021 | 01:37 PM
The REGION forums are intended for geographically relevant topics such as meetings or recommended specialists. Technical questions should be posted in the relevant MODEL forum.
BigJono
Jan 15, 2021 02:12 PM
steve123456srm
Aug 3, 2018 09:50 AM
asifr
Apr 25, 2018 02:30 AM
RodTee XF
Apr 6, 2014 07:48 AM
scottjr1
Aug 6, 2012 08:45 PM
