US Western AK, CA, NV, OR, UT, HI, WA, ID
starter will only crank for 1 to 2 seconds and stops
Old Oct 8, 2023 | 03:54 PM
John Bear's Avatar
Default starter will only crank for 1 to 2 seconds and stops
My 2009 XJ will not start, It cranks for about 1 to 2 seconds and stops.cranking on its own, while I hold the key in start position. .Battery is charged and I also tried "jumping" with no change in the problem. Any ideas on what could stop the starter from turning the engine. Thanks in advance for any ideas. JOHN BEAR
Old Oct 9, 2023 | 07:12 AM
clubairth1's Avatar
Community Influencer
Pull the starter and check if it's good on the bench.
If it is then turn the engine over with a wrench and see if the engine is locked up?
mhminnich
Mar 19, 2020 07:36 AM
Zorro
Jul 16, 2019 09:34 AM
b787
Jun 18, 2015 05:08 PM
dinerdash
May 15, 2013 07:30 PM
jasper
Jan 16, 2010 04:08 PM
