US Western AK, CA, NV, OR, UT, HI, WA, ID
XJR Coolant Recovery Tank
Old May 14, 2017 | 06:43 PM
Kwonnnny's Avatar
Default XJR Coolant Recovery Tank
My Low Coolant alert came on, so I stopped to check the level and for leaks. Noticed the area was wet around one of the small hoses, so I moved the hose around and it started leaking more.
I thought that the hose clamp had failed, so I loosened the hose clamp, pulled off the hose to replace the clamp and the whole nipple stayed inside the hose.
So I am looking for the most reasonably priced Coolant Recovery Tank for a 2004 Jaguar XJR.
I've found it online for $172 with the sensor, but I have also seen that the Coolant Recovery Tank for an XJ8 of the same year is 3.5 times less expensive, $45 or so.
Will this XJ8 tank work on the XJR???
Thank you in Advanced.
