Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
spruce up wheels ? - 95 xj6
Old Dec 16, 2009 | 08:46 AM
thisheregirafFe's Avatar
Default spruce up wheels ? - 95 xj6
Hey all,
Got a bit of a problem with the alloy wheels in my new (old) cat. The wheels are starting to look pretty sad and I'm wondering if I can clean them up. It looks like kindov a blend between curb rash & possibly oxidization. Also, it looks like whomever put the tires on last had a helluva time balancing them because you can see where the weights have been clamped down, unclamped, moved, clamped again etc.
Anyhow what i'm left with is kindov a chewed up look in parts and a creeping whitish junk in areas, with two wheels being worse then the others. the spare looks amazing, so i can swap that out easy, but is there anything you'd recommend to try and clean them up ? rubbing compound ? brake cleaner ?
Old Dec 16, 2009 | 02:20 PM
H20boy's Avatar
Try the detailing area giraffe, there may be more advice and content over there. Have you considered just having them 're-finished' for around $125 each? I've had a local place do mine. They'll blast it and start over, making them look brand new.
H20boy
Dec 24, 2024 03:23 PM
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
carcycle
Sep 7, 2015 04:14 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
