car wont gointo gear even though gear shift moves
Old Jan 8, 2014 | 11:28 AM
boatus123's Avatar
Thumbs down car wont gointo gear even though gear shift moves
got car stuck in 12 inches of snow. rocked it a few times. now when I shift the car won't gointo gear. did I bend the linkeage? or did my transmission go
Old Jan 8, 2014 | 12:47 PM
I've copied this question from your Intro for advice from members with the same model.
Hope it's an easy fix.
Old Oct 22, 2020 | 07:11 PM
toronadomike's Avatar
Thank you for the ideas. 8000 miles ago a different problem prompted me to install a new conductor plate and six new shift solenoids. At the same time I realized that a failing freezing shift cable was not putting the trans shift lever exactly where the console shifter switch thought the gear selection should be, Hence I installed new shift cable (which also fixed the door unlocking problem). Everything worked great for 8000 miles, with no signs of transmission fluid leaking. tonight I did find the transfluid to be 1 quart low. so I added 1.5 quarts. The "P0730 gear ratio incorrect" still doesn't clear with with my OBD-2 scanner. Is a "hard reset" disconnecting the battery overnight?
Thanks again,
Mike
Ronald david
Jul 22, 2020 05:37 PM
trevor24
Oct 8, 2017 01:44 PM
wotcham8
Nov 9, 2013 07:05 PM
Disco stu55
Aug 28, 2011 02:04 PM
rdp
Nov 4, 2009 07:00 AM
