Changed ATF
Old Feb 18, 2007 | 03:26 PM
racerx82's Avatar
Default RE: Changed ATF
You should have tapped into the trans cooler line, and with the engine running, drained all the fluid....the torque converter, cooler lines and transmission... I'm sure doing it that way you would have been closer to the 8 liters
Old Feb 18, 2007 | 03:39 PM
racerx82's Avatar
Does it say to keep the engine running while the oil plug is removed?
I know from experiance you won't get any of the fluid out from the converter unless the engine is running
Old Feb 19, 2007 | 10:58 PM
racerx82's Avatar
With all the time you wasted so far, you could have replaced the tranny...
Drop both cooler lines, have a pan or bucket ready, put both lines in the bucket and hold on to them. Have someone start the car. The fluid will run out with some force so hold on to it. When you see the fluid slowing down shut off engine..
That should drain most of the fluid and bring you closer to the 8 liters.
Old Feb 19, 2007 | 11:37 PM
racerx82's Avatar
lol, ok, well lets us know what you find to be the best way......you're right, lots of us do want to know....
Old Feb 20, 2007 | 11:58 AM
bigdreams05's Avatar
LOL! Nice write-up! I'll be doing the SAFE method in about a week or two. Thanks!
Old Feb 20, 2007 | 05:09 PM
ruslan35's Avatar
Thanks for a great post!!!
I am getting ready to change mine (02 2.5) but i have a few Qs:
1. Cant find a refill plug. Can you describe its location a more specific, or perhaps post a photo.
2. Just to get it straight: you used Valvoline's Mercon V ATF with your change?
3. What about a filter? Did you change that?
Thanks in advance!!!
Old Feb 21, 2007 | 12:12 AM
racerx82's Avatar
Yeah, i think i'll do the synthetic stuff...
(mine is still under warranty, so if it fries in the next 3 years i'm covered lol)
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
