Help
Old May 19, 2014 | 08:09 AM
cascar's Avatar
Angry Help
Hi I am new to the site i have an x type diesal estate which is driving me mad there is black smoke pouring out the back on accelaration,i have had the egr replaced the air mass sensor cam sensor and the map sensor replaced the air filter etc i have put the higher grade diesal in it oh and also the intercooler has also been replaced but to no avail i am tearing my hair out here can anyone help? its a 2008 reg and its done 59k
Old May 20, 2014 | 04:58 AM
alan924's Avatar
What diagnostic codes are being given?
Old May 20, 2014 | 05:24 AM
Five Speed's Avatar
Also try the UK Jaguar Forums ... This site is Basically USA , so the diesel info is limited , as Jag never sold diesels in USA ...
Old May 20, 2014 | 04:49 PM
cascar's Avatar
No Code given and no engine mangement light on
Old May 20, 2014 | 04:53 PM
Thermo's Avatar
Veteran: Navy
cascar, from the sounds of things, you have a fuel injector that is stuck open and what you are seeing is the raw fuel dumping out the exhaust. I would recommend having a leak down check done of your fuel system and see if you can find which fuel injector is leaking on you.
Old May 22, 2014 | 08:01 AM
cascar's Avatar
Thanks Thermo,
Will have that looked at next will post results
