how to replace outer rear control bushings
Old Jul 5, 2014 | 12:08 PM
jagjeep guy's Avatar
Default how to replace outer rear control bushings
2002 jaguar type x-I am replacing rear lower control arms and found outer bushings no good-jag calls them bush rear hub carrier-what is best way to remove and install new ones-thx
Old Jul 7, 2014 | 06:09 AM
Paulc732's Avatar
jagjeep
best way to do this is with
OEM/Ball joint/U-Joint press set (27023) | Loan-a-Tools | AutoZone.com
you will find that the press parts are just a little off the size you need so go to your local hardware store and get a 1 1/2" or could be 1 1/4 inch close nipple and a 3/4 to 1/2 inch coupling
also while your there (take your new bushing with you) get some threaded rod some nuts and washers this is to pull in the new bushing.
now your asking why dont i use the threded rod to pull out the bushing? You can what you need the kit for is the two big washers for want of a better word.
use a little anti seize or oil on the bushing to help it back in.
have fun. stay safe
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Doug Dooren
Aug 30, 2015 08:51 AM
perfectphoto
Aug 29, 2015 10:11 PM
dpappyp
Aug 27, 2015 06:31 AM
