Poor Starting
Old Jan 25, 2015 | 07:16 AM
Timbow's Avatar
Default Poor Starting
Can any one help, have a 2008 X-Type 2.2 diesel, poor starting, changed the battery but no change it's like the battery is only half charged
Old Jan 25, 2015 | 07:19 AM
Tim,
I've moved this question from your Intro thread to X-Type forum. Members here with the same model will be able to help.
Old Jan 25, 2015 | 07:41 AM
Timbow's Avatar
Old Jan 25, 2015 | 08:34 AM
salim's Avatar
the new battery has the correct specification? terminals are clean and tightened?
Old Jan 25, 2015 | 09:23 AM
Alfadude's Avatar
Welcome to the forums, Timbow. There are a lot of friendly and helpful people on help willing to help. However, being primarily a US site there are less members familiar with diesels as they aren't sold here, so it might take a bit longer for someone to chime in. You can also help your cause by giving more detailed info on your situation than a brief generic description that it has trouble starting. Was the car running great and all of a sudden did this just come up? Did you recently do any work on the car before this happened? Are there any check engine lights on and if so, can you get the codes read and then post them here? The more detail you give the better chance you have of getting a quick response.
Good luck, I hope your issue gets sorted soon!
Old Jan 25, 2015 | 11:39 AM
Timbow's Avatar
2.2 turbo diesel starting problem,Replaced old battery as a cell went down, ok at first, then slow to turn over as if battery was flat or just a single click when turning the key, checked the connections and that the battery was charged, no warning lights on dash, not been able to get any codes
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
mrplow58
Sep 9, 2015 11:27 AM
Bones
Sep 8, 2015 08:34 PM
Mosers63
Sep 6, 2015 02:53 PM
