02 xtype dead...hoping for the best
Old Sep 25, 2011 | 07:48 PM
johnnytj's Avatar
Default 02 xtype dead...hoping for the best
my 02 xtype 3.0 liter shut off while my 16 yr old daughter was driving she explained she applied the brake and it shut off..wld not start back nor even turn over. Towed it hm tested batt it is good, headlights come on, radio, dashlights all wrk..windows will not roll dn nor will the trunk open..i can arc the starter and will turn over then but not start...what could be wrong...ecu?ecm?security lock?faulty coil or wiring
? help any clues!
Old Sep 25, 2011 | 08:04 PM
cujet's Avatar
Fuse?
Old Sep 26, 2011 | 04:46 AM
Thermo's Avatar
Veteran: Navy
johhny, it sounds like to me that the ECM (the computer that controls the engine) has lost power. I would check the fuses for the ECM first. But, if those are good, then odds are you are looking at an ECM.
If you want more info, let me know.
Old Sep 26, 2011 | 05:19 PM
sidewalkman's Avatar
Sounds very similar to my issue, except mine didn't shut off. I'm still waiting for it to happen again, but always when applying the brakes it would go into all different faults, try disconnecting the battery first for about 5 minutes.
If everything disappears you might have a code, if it's P0221 or similar you might have to get TB cleaner, dismantle the throttle body and thoroughly clean it. I'm not sure if mine is fixed or not but it's been a couple of weeks with no more issues.
Finbarr1975
Oct 4, 2015 05:32 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
BlakeConverse
Sep 28, 2015 02:22 PM
JagLove86
Sep 15, 2015 07:05 PM
1LowCat
Sep 14, 2015 07:51 PM
